vsiicalais
Donating Member
- Aug 23, 2007
- 295
- 11
- 18
- Location
- Wonthaggi
- MY15 VF SV6 Storm
VS Computer V6 Fault Codes
V6
Code 12 - System Pass (OK)
Code 13 - RH Oxygen Sensor (O2)
Code 14 - Coolant temperature sensor low voltage
Code 15 - Coolant temperature Sensor high voltage
Code 16 - Coolant temperature Sensor voltage unstable
Code 17 - ECM Error - Coolant temperature Sensor
Code 19 - Throttle Position Sensor (TPS) stuck
Code 21 - Throttle Position Sensor (TPS) high voltage
Code 22 - Throttle Position Sensor (TPS) low voltage
Code 23 - Mass Air Temp Sensor (MAT) high voltage
Code 24 - Vehicle Speed Sensor (VSS) Auto
Code 25 - Mass Air Temp Sensor (MAT) low voltage
Code 26 - Mass Air Temp Sensor (MAT) unstable voltage
Code 28 - Pressure Switch Assembly Short Circuit - Auto Transmission Only
Code 31 - Theft Deterrent Signal missing
Code 32 - Manifold Air Flow Sensor
Code 35 - Idle Speed error
Code 41 - Electronic Spark Timing Circuit (EST)
Code 42 - Electronic Spark Timing Bypass Circuit fault (EST)
Code 43 - Knock Sensor Circuit
Code 44 - RH Oxygen Sensor Lean (O2)
Code 45 - RH Oxygen Sensor Rich (O2)
Code 46 - No Reference Signals while cranking
Code 47 - Crank Angle Reference Signal
Code 48 - Cam Angle Sensor
Code 49 - Crank or Cam angle Sensor Intermittent
Code 51 - Memcal Unit
Code 52 - System Voltage high (auto)
Code 53 - System Voltage high (auto)
Code 54 - ECU Power supply variation
Code 55 - ECM
Code 57 - Injector Power supply voltage variation
Code 58 - Transmission Fluid Temperature - Auto Transmission Only
Code 59 - Transmission Fluid Temperature - Auto Transmission Only
Code 63 - LH Oxygen Sensor (O2) - No Signal
Code 64 - LH Oxygen Sensor Lean (O2)
Code 65 - LH Oxygen Sensor Rich (O2)
Code 66 - 3 - 2 Shift Control Solenoid Circuit Fault - Auto Transmission Only
Code 67 - TCC ON - OFF Solenoid Control Fault - Auto Transmission Only
Code 69 - TCC Stuck ON - Auto Transmission Only
Code 72 - Vehicle Speed Sensor (VSS) - Auto Transmission Only
Code 73 - Pressure Control Solenoid Current - Auto Transmission Only
Code 75 - System Voltage Too Low - Auto Transmission Only
Code 76 - Air/Fuel ratio variation between left and right banks
Code 78 - Air/Fuel ratio variation between left and right banks
Code 79 - Transmission Temperature Too High - Auto Transmission Only
Code 81 - 2 - 3 Shift Control Solenoid Fault - Auto Transmission Only
Code 82 - 1 - 2 Shift Control Solenoid Fault - Auto Transmission Only
Code 83 - Torque Converter Clutch Circuit - Auto Transmission Only
Code 92 - Low Speed Radiator fan response signal
Code 93 - SNEF Circuit Fault
Code 94 - Vehicle Speed Sensor (VSS) - Manual Transmission Code
Code 97 - Canister Purge Solenoid and/or Circuit
V6
Code 55 - ECM
