Nick Scali
- Dec 30, 2022
- 45
- 15
- 8
- Age
- 89
- Location
- Melbourne
- VSII Caprice
Good evening, all,
Fired up the old shitbox and gave her a bit of love today (service).
Taking the RHF wheel off and having a bit of a goosy gander, we've spotted this:
Ignore me jocks being used as a rag for all you train spotters out there,
The RHF rotor is very loose inside the caliper assy, there's a shitload of play there allowing the caliper and rotor to slide around heaps.
Not sure if this is usual, the pads are still in good condition, probably 50% maybe more.
LHF - perfect, it doesn't move about what so ever:
If you push the brakes on the rotor obviously tightens up in the assembly, but then loosens off again.
Could it be the piston inside the caliper has recessed in and now has to travel further?
Pads are around 50-60% so they're not super low or anything.
The car brakes like **** too, it won't lock up the brakes and bring on the ABS, even with rubbish ecotyres on it, when I absolutely stand on the brakes it just slows down a bit and you lean a little out of your seat. It doesn't pull to one side.
The only way I've been able to bring the ABS on is go on a dirt road and stand on the brakes, its the only way I've been able to get them to lock up, we've got a problem but I'm at wits end here, the brakes have been typical shitty 1990s Australian car brakes, but never been this bad before.
Let me know your thoughts, is this a calipers off for reco job or is there something more sinister at play here?
Thanks all
Thanks all
