Im putting a vt 5.0 litre into a manual hilux
Ive had the security settings removed, had a manual chip put in, the ecu has been tested with the dizzy and ignition module at the same time and were working as they should as were all the plugs on the loom getting signals
Im getting spark and injector pulse which was tested with a noid light
It wont fire up, im thinking its a fuel problem, has anyone ever had a blocked fuel regulator or fuel rail? is it common to do so
I have put reco injectors in, changed plugs and leads, i can hear my fuel pump priming
The main fuel feed is hooked up the the regulator so its on the correct side,
The thing that makes me wonder if the regulator is blocked is i have the fuel return line from the injectors not hooked up, should i be getting some excess fuel coming out of that when the pump primes, as im not getting any, after cranking i have pulled out the plugs and they are dry, all sensors are connected, i have taken off the main fuel line before the regulator to test if the pump is working fine and it is getting fuel there
all the earth fires are connected up to the motor, chassis and battery
any body got any ideas what it could be
i just want to make sure its going to fire ok before i start putting the radiator thermo fan etc etc back on
thanks
thanks
