Vt commodore
SuchIsLife13
VT super 6 spack
I got a new VT S PACK II,
i took out my old BCM, ECU, steering wheel + collom, wiring loom and motor and put it in the s pack,
wired it all up and went to fire her up and come accros a problem,
The engine, ABS, oil lights have come up... aswell as "SERV ERROR" on my little dash screen...
if i took it to a auto electrition and got them to relink the bcm to the ecu and clear the codes..
would it be fine? hopefully?
Cashman_309
VTII Calais
PCM and BCM are not linked.
Take to a holden dealer or find a tech2
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Were the ECU and BCM that you put in a matching pair, did the come from the same vehicle? If not then they would need to be linked but if the were already linked they should not need to be re-linked.
Wouldn't it have been easier and cheaper to replace the timing chain?
SuchIsLife13
VT super 6 spack
It's the original bcm and ecu out if the same car. :/ what could it be?
Cause I'm on my P's :/
Danny
Blue mountains
Soon to get WL
Also need the same key head to match so you need ecu bcm and key all from same car
lout
60
Langwarrin Victoria
blown fuse under steering column to ECU or loose connector to ECU
basically the ECU is not getting power or "new" ECU is faulty
Cashman_309
VTII Calais
Or of course the person who sold the lot to you 'said' it came from the same car but probably didnt.
SuchIsLife13
VT super 6 spack
Nah I pulled the BCM, ECU wiring loom everything out of my old vt commodore
customcom
sydney
vx
sounds to me like ur key needs coding to match the rest of it :) im no expert just my thoughts
