VT Gen 3 intermittent low idle
Anglosaxon
55
VT SS S2
Sometimes when I pull up to a stop my engine sounds like its about to stall, it almost sounds like when you slow a manual right down with the brakes without pushing the clutch in (but its an auto), if i slip it into neutral the idle pops up to normal. It never actually stalls, and it only does it sometimes. Anyone come across anything like this before?
m1lky
Auckland
VY SS
Could be a small vacume leak?
If you think it's tranny related, I would just change the fluid. Nice and easy and it will be smoother for it
Anglosaxon
55
VT SS S2
Yeah I'm thinking tranny, due to the fact I can actually hear the load come off the engine when I put the trans into neutral, I guess I was wondering if its a known symptom of something (serious or not) that im unfamiliar with, I'll service the trans hopefully that'll help.
Cheers.
wassup353
Series 2 VX SS
What's the best way to change the fluid without letting too much air sneak in?
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
don't worry about air getting in, I'd be more worried about spilling the fluid over the engine
wassup353
Series 2 VX SS
Because i topped up my fluid and got the same intermittent idle as discussed above. I'm guessing it was because too much air got in?
Munz
Right Foot Action
Brisbane NTH
Try a PCM reset
PCM reset Proceduce
Motor at operationing temperature a MUST
1.Turn ignition ON
2. Model VT Remove PCM/BCM fuse number 4 which is F31 Note: for VX,VU ,V2 remove fuse F29 10amp Eng Cont/BCM
3.Wait 20 seconds for the Car to chime to you.
4. Turn ignition OFF.
5.Model VT Replace PCM/BCM fuse 4 which is F31 Note: for VX,VU ,V2 remove fuse F29 10amp Eng Cont/BCM
6. Proceed to the idle learn Procedure.
CLEARING THE DTCS
To clear a current diagnostic trouble code from the memory of the PCM, the PCM power feed must be disconnected
for at least ten (20) seconds, or the Tech 2 scan tool must be used. The battery power feed can be disconnected
by:
• Disconnecting the negative battery terminal
• Removing the Fuse F31 in the engine compartment fuse/relay panel.
CLEARING THE DTC HISTORY CODE
The Tech 2 scan tool is the only tool capable of clearing the DTC history code. Disconnecting the battery will not
erase DTC history. The Tech 2 scan tool sends a special message to the PCM to erase the DTCs.
IGNITION CYCLE DEFAULT
If the ignition is cycled (OFF and ON) 50 times without a particular fault resetting, that DTC will be cleared from the
PCM memory and the ignition cycle counter in the PCM will reset to zero. This is another way to clear any code, but not all, but might help you out.
Then follow the idle learn procedures
Idle Learn Procedure
Anytime the powertrain control module (PCM) or the battery is disconnected, the PCM loses power
by removing F31, or the PCM is reprogrammed, the PCMs learned idle position is lost.
Perform the following procedure in order to return the learned idle to the correct position:-
Automatic Transmission
1. Turn OFF the ignition.
2.Restore the PCM battery feed if removed, or replace fuse 4 which is F31.
3.Turn OFF the A/C controls.
4. Set the parking brake and block the drive wheels.
5.Start the engine.
6.Ensure that the engine coolant temperature is more than 80 Degrees.( Check in Mode Up button).
7.Shift the transmission into Drive.
8.Allow the engine to idle for 5 minutes.
9.Shift the transmission into Park.
10.Allow the engine to idle for 5 minutes.
11.Turn OFF the engine for 30 seconds.
Manual Transmission
1.Turn OFF the ignition
2.Restore the PCM battery feed if removed, or replace Fuse 4 which is F31.
4.Set the parking brake and block the drive wheels.
5.Place the transmission in Neutral.
6.Start the engine.
7.Ensure that the engine coolant temperature is more than 80 Degrees.( Check in Mode Up button).
9.Turn OFF the engine for 30 seconds.
wassup353
Series 2 VX SS
Tried the PCM reset and if anything it made things worse, nearly completely stalled at one point during the 5 minute idling period!
Munz
Right Foot Action
Brisbane NTH
Did you try the idle learn procedure?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Faulty TPS or coolant temp sensor.
