Vt help.
kp18
VT COMMODORE SERIES II
VT holden is chewing through petrol, 70 dollars of petrol only got me 200 kms or less. Cuts out after driving for a little while, could it be the fuel pump? changed crank angle sensor and coil pack. please help.
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
The high fuel usage could be due to worn out oxygen sensors. If they have not been changed in a long time it might benefit you to do so.
Tasmaniak
Not a valid input....
S.E. Melbourne
www.ranjinstallations.com.au
Definetly agree with accenstencil but even for plugged up o2 sensors, that seems a bit excessive. Does the car happen to be blowing a bit of black or grey smoke? It might be running rich although I would assume that would throw a CEL
kp18
where are these oxygen sensors located? thanks.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
$70 of fuel is like what, 5L now?
Jokes aside, I'd check the pump if it just cuts out, the O2 sensors may contribute to high fuel usage but they won't cause it to stall.
Do you know how to do an error code check?
kp18
no i dont know how to check it, how do i check them?
