mattyvt
I know this is a pretty common issue with the VT and ive done alot of searching on it, but one thing i cant find is the method to replace the ignition switch.
Basically, my key doesnt spring back from when you crank the engine over and when left, the start motor grinds. So im manually turning the key back. Ive read that it is the ignition switch and have been told by a few locksmiths/auto elecs the same thing also.
What im looking for is the easiet way to remove and replace. Do i need to remove the whole barrel, or is it as simple as removing the housing and then unscrewing a couple of screws and switching it over like on a VS i believe and like a 10min job?
Ive been quoted $55 for the switch and $99/hr labour in Morley.
Thanks
Thanks
