Reed93
- Apr 14, 2014
- 12
- 0
- 0
- Age
- 30
- Location
- Reservoir, Victoria.
- VT Calais L67
Okay I'll try to explain it the best I can.
The car idle sounds as if the revs are going up and then dropping, happens every 2-3 seconds but the revs don't seem to move on the dash. It doesn't do it when you first start the car, happens a minute or two later.
When driving normal it sounds fine, then when I plant my foot it sounds horrible, splutters off its head as if it's missing. The leads and plugs have just been changed. I'm near positive they aren't the problem.
What else could be causing this ? It doesn't seem to be doing it all the time but 90% of the time it is. It sounds putrid and is quite embarrassing.
Been told a few things.
Coil pack
Coil pack module underneath.
Maf sensor
Vacuum hose.
not sure if it helps but the car has and aftermarket exhaust, pod filter, 10psi pulley. Only started happening recently though
Any ideas ? Thanks in advance!
Coil pack
Maf sensor
Vacuum hose.
