Seems the engine is leaking a small amount of oil right at the top bolt where the manifold joins with the engine. Anyone have a plan how to fix this problem?
Cheers, Ian
Cheers, Ian
Spanner and pinch it tight make sure it ain't loose. And come back with a reply. I'm also wondering if there is oil leaking down from your rocker cover, (one of the grey plastic things on the side of the engine just above your plugs)
