Vt S-pack 2001 Series2 Instrument warning lamps problem
pixelpwn
port macquarie Nsw
VT Ecotec Series 2, 2001
When i start the car there is an error and some of the instument lights light up and then about 5 seconds after it starts to make beepin noises and the rest of the instume nt lights turn on and the engine cooling fans start and will not stop untill i turn car off.
Ill be uploading a youtube vid soon. jsut so youse get a better idea of what im trying to explain hahaha. - www.youtube.com/watch?v=6DZmlcG4K_s&feature=youtu.be
At first when i turn the car on -
5 seconds after that (it beeps several times and these lights come up) -
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
cluster it's recieving data from the databus. All fuses good for a start?
st3r3otyp3
Donating Member
VX HSV VX SS
ABS module is probably about to **** it self, oddly the only warning light not illuminated is ABS.
st3r3otyp3
Donating Member
VX HSV VX SS
I suspect the abs warning light globe is blown and should be illuminating. seems a lot of ABS modules are crapping themselves lately.
Husky
Pakenham
VXII L67 Berlina Wagon and VEIISSV M6 Sportswagon
Unplug the abs module and start then car. Only the traction and abs wearing light should come on. Although like it says a above I'd say your abs light is stuffed.
If this works replace the abs module.
Sent from my C6603 using Tapatalk 2
pixelpwn
port macquarie Nsw
So I was thinking about the engine fan thing , could it be the thermo switch any chance?
ashbox
back in black
The Car
something black
abs module should only cause the abs, trac off and low trac lights to illuminate, not the check engine, check oil etc..... and it wont bring up the service error.....
get someone with a tech 2 to go over it and scan for any codes etc
st3r3otyp3
Donating Member
VX HSV VX SS
@ ashbox yes in fact it will, It happened to me oil light and all, the abs fault tricks the pcm and bcm and sets off other sensors even the fuel gauge reads full on some start ups, change the module and all goes quiet 100%.
