VT serpentine belt change
MXBM
VT wagon 17"mags
G'day Guys,
tried to find some instructions so I could sucessfully change my serpentine belt on my VT wagon.
Couldn't find, hence, this post.
Anyone able to assist me with either a link or instructions please?:driving:
Mick :)
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Get a 15mm spanner or socket and put on the bolt in the centre of the tensioner pulley ( that's the one just below the alternator pulley) then while standing on the driver's side of the engine pull the spanner hard toward you, as you do you will see the belt is becoming loose and you can just pull it off. You put the new one on the same way.I find it easiest to thread the belt onto all the pulleys exept the water pump pulley, then pull the tensioner pulley with the left hand and slide the belt onto the water pump pulley with the right hand.I would suggest that make a diagram of how the belt runs beforehand so you can put it back on the correct way. Make sure the belt is sitting correctly in all the grooves.
MXBM
VT wagon 17"mags
Cheers Bro!
