Vt supercharged manual conversion
Sam5467
27
Boyne island
vt Berlina supercharged
Hey first time posting, I want to manual swap my 2000 vt supercharged v6 commodore, i was wondering if i can use a vn t5 gearbox with and 8 bolt flywheel? is there any other things i need to get or will it work
thank you
gtrboyy
vt ss & lc gtr
vt are hydraulic clutch setup while t5 cars were all cable clutch & different speed sensor plus few other things like ecu,tailshaft etc
vt & some vs models had getrag with hydraulic clutch
Might want to do some research before turning a spanner
_R_J_K_
Zenki S14
Don't use a T5, will require lots of custom fab, the most fiddly of which will either be making a custom pedal box that pulls the cable clutch instead of pushes a master cylinder, or converting the T5 clutch to be hydraulically actuated.
Just get a complete Getrag conversion out of another VT.
