Co-Pilot
- Feb 18, 2013
- 13
- 0
- 1
- Location
- Brisbane
- VT Calais Supercharged
Co-Pilot
Hi Guys Hope this helps you. My supercharged VT had similar overheating problems it was easily fixed in my case. I found that the hose to the overflow tank had gone brittle and broken off just where the hose enters the overflow tank neck but just inside the overflow tank neck, this looked fine from the outside but was stuffed. This broken hose worked fine whilst water got hot and therefore expanded and emptied into the overflow tank. But when the water in the radiator cooled and therefore contracted and tried to suck coolant back from the overflow tank it just sucked air as the broken hose in the overflow tank neck was not immersed in the coolant fluid of the overflow tank - end result nothing to suck back and overheating due to low coolant level in radiator. I removed the overflow tank and got the old bits of hose out of it, reinstalled it, replaced the damaged hose and made sure that the replacement hose reached the bottom of the overflow tank. I made sure I cut the bottom end of the hose at a sharp angle (about 70degress) to stop the hose sucking on the bottom of the overflow tank which, if it did this would also not suck back coolant. This new hose worked a treat and I have had no problems since. P)
