Wayne Hocking
- May 29, 2019
- 2
- 0
- 1
- Age
- 55
- Location
- Mildura
- VU S Series Ute
Hi all, I have a VU Ute and when driving the dash lights will come on, the same dash lights as when you turn on the ignition. After a couple of seconds they will all go out with the seat belt light staying on a little longer than the others, just like when you start the car.
The fuel gauge resets and slowly climbs back to the correct position.
The tacho continues as normal, but the temp gauge and speedo dip down and recover.
The air con has to be turned back on.
The car keeps running as normal and the cruise continues to work while the lights are on.
The stereo (aftermarket plugged to the original loom via Aerpro) continues to work as normal.
I have read similar posts where faulty ABS gets the blame, the standard VU S Series does not have ABS or traction control.
It seems as if the BCM is resetting.
This has happened four times in the last year, but two of those times were on my way to work this morning.
