vu ss suspension?
TMan12
33
Wellington
02 VU SS Ls1 5.7
hi i have a fairly rough ride especially from the front on my vu ss its sitting on 19s with low pros on it im trying to get a more comfortable ride also its been lowered on to who knows but sick of the bumpy rides can any1 help with suggestions cheers
_R_J_K_
Zenki S14
Smaller wheels and higher springs are a good start. Shocks mainly if they're pretty old.
Vin999
SA
VSedanS
vc commodore
Like the Leyland Brothers
VC, VH and VY
The easiest way for a start, is go a higher profile tyre....Personally I'd be looking at 225/55X16, just for that tyre sidewall flex, which helps cushion the bumps...
From there, you can raise the suspension, which also helps with ride comfort.....Depending on your budget, you could go the coil overs as suggested, or you could just go with factory style springs.....Personally I'd be going FE2, which is 50 MM lower than standard factory height (which is the same height as police cars), or you could go standard height....Choice is yours
So a few options you could try
