pepstar87
- Apr 27, 2008
- 326
- 0
- 0
- Location
- Central Coast, NSW
- 08 SSV M6
My 2001 VX executive is having problems with the air con.
I switch the air con on and there is no air coming from the vents when the switch is on 1, 2 or 3.
When it is on 4 it begins pushing air out, but in 1 second bursts, and the stereo and dash lights start flashing. The AC light also turns off on 4 (weird)
So I swapped the fans over from my dads VX to see if it was just the fan, however it still doesnt work on 1, 2 or 3..but works on 4 fine. The AC light also turns off again on 4??
I changed the fuses, and they're fine so thats not the problem.
Do you think replacing the fan and possibly the switch will fix the problem? As the switch doesnt seem like it is registering when it is placed on 1, 2 or 3.
Or is there anything else that is a common problem that will fix this issue?
Thanks guys.
Thanks guys.
