Speedwayracer3800
- Sep 8, 2015
- 10
- 0
- 0
- Age
- 47
- Location
- W.a
- Vy proddie
Hi all first time ever posting in any forum so I'm breaking my virginity, ok I've recently bought a vx v6 commodore for a good price ($400) as the young owner didn't want it because it was unreliable and he couldn't get it going I turned up with jump leads gave him money started it and drove off but on the way home approx 40mins later it stopped. I had a good idea it was the cas anyway, trailered it home and removed the balancer and replaced cas to my surprise the cas looked brand new Delphi too.
So I changed it anyway and started straight away but I noticed there was a knocking sound that was coming from balancer was definitely not there before car ran smooth with no abnormal noises before,so I tightened balancer some more and it went away but what I noticed us when the knocking was happening there was a knocking sound coming from right top end head almost like a detonation knock, I drove it some more and again the balancer was knocking this time I took to it with all I had including ratchet gun, it seemed good I took a chance and drove it 100ks away drove perfect so on the way home I gave it a little and then when cruising at 110 the cel came on but would go away when I depressed accelerator pedal and let it off a bit it did it a few times on way back but I could make it go away every time by doing as I described.
The first set of lights I came to when I got off the hwy I noticed straight away the knocking from balancer was back so I put it in nuetral and revved it and sure enough the knock from right bank top end was back,now my question is could the knock from the balancer be making the knock sensors pick up a false engine knock? Also what's with the CEL coming on and going with accelerator movement? There is no broken valve spring or anything like that somehow the knocking of balancer us connected to it all I think and any thoughts why the cas that I removed was brand new but failed? Sorry for long post trying to give the best description I can
cheers
cheers
