On the first run when it really stuffed up I was using unleaded 95 but have been told since to only use 91 ??What fuel you running? My plugs looked about the same as yours, I do have a slightly earlier engine.
Yes I can do that but the program and lead I bought doesn’t seem to work for me I emailed the guy I bought it off and he said just follow the instructions I did still didn’t work I did take it to get a diagnostic done the first time it played up, as I wasn’t thinking of engine damage after 54ks, but the only faults it thru up was cam angle sensor missing ? They put a new one in still same result hence compression test after that they didn’t look any further although he did mention that manifold temp was fluctuating a lot but I guess that’s because of the valvesDo you have a way of plugging your laptop in to the ECU, like you can on a VX?
