Jxfwsf
The link you posted means zip. Its designed to suck people in, I was sucked in once.
Obviously you have made up your mind that with K&N you are on a winner.
For race cars what you say maybe true, for street driven cars waste of time and money.
Quote: I want a link that shows the actual filtration of the filter vs others.
You must be really lazy. Search the site I posted early. Plenty on that site.
Reread what I have actually said.
Your posting has told me plenty already.
You mean links like this?
Paper & Foam vs K&N# Oh wait that ones a bit biased...
Motocross Action Magazine | TEN THINGS YOU NEED TO KNOW ABOUT AIR FILTER OIL
https://www.google.com.au/?gws_rd=ssl#q=oiled+foam+air+filter
But leaving names out of it, oiled foam filters aren't anything new and are often used because they are better in certain circumstances (honda 4 stroke engines come to mind here with a combination paper/oiled foam filter), layers of cotton gauze work much better, i guess instead of engine oil you could go with bar & chain oil with it's modifiers that cling to things better, with a low viscosity so should really catch all the dirt n clog up
Doesn't mean paper is better or worse, but if not in a city and saw a lot of dirt roads i'd certainly use something that is better at catching all the nasties (if it breathed better then that's a bonus) even if i had to clean it every 1000 km's.
Although as mentioned earlier if not maintained correctly will do more harm than good with an efi engine.
