holden hurc
- May 18, 2009
- 3
- 1
- 0
- ve ss
there was problems with hazzard light switches, operate switch a couple of times and then try your indicators if operating ok then hazzard switch needs replacing. other things that used to buzz/click was relays internally in body control module, which means new body control module and 2 new keys with a trip to a holden dealership or workshop with decent scan tool to program new keys and link BCM to PCM. Some workshop aftermarket scan tools also have the ability to do this so you dont have to go to a Holden Dealership to replace the BCM. These BCM`s are a couple of hundred dollars and key remotes are about $60-$70 each. when its buzzing or clicking try and feel if its comming from BCM under steering wheel above accelerator pedal large grey plastic control module. part number is on its sticker, first part of numbers are small numbers on sticker and include last 3 digets which are large in top right corner of sticker.also may say mid or high on sticker depending on level of vehicle. The flasher can/relay could also do this which is in fuse pannel above fuses larger black looking relay. So try and feel which one is making noise with fingers, and dont forget to try the hazzard light switch as mentioned above.
