goldvnaero
HOLDENS RULE
Hi there,i have an auto VX SS which has had a mafless tune,new rebuilt trans with all the usual good bits and a 2800rpm stally,pacemaker tri y's with high flow cats and an OTR CAI. It made 247rwkw on the last dyno run which was 6mths ago,but since then i have had the trans and exhaust done to what is mentioned above,previous trans was slipping and had an old crappy HSV exhaust on it which had a crappy droney note,have also had a touch up tune to match but havent had a recent dyno. Anyway,that isnt the problem lol. The last few weeks it has been playin up a bit,when revving it in park or neutral the revs go so low that it almost stalls and it also does this when slowing right down. I have recently changed the TPS and ISC sensors thinking that this might resolve the problem but it hasnt,so today i did the plugs and leads and gave the TB a good clean out and checked for any vacuum leaks,also cleaned the battery and the terminals and also reset the PCM several times but to no avail. Also has a brand new Battery as well,the surging issue started before the new battery,it actually started after i got the car back from getting the new trans,The mechanic there told me it was normal and that the ECU would reset itself after a little while,and it hasnt,So i asked the guy that did the mafless tune to have a look at it for me and he said it all looks normal,but it isnt.any ideas guys???
Just wondering if you guys have any suggestions or if anyone has encountered this problem before,i have read alot of things on here about the same problem,but all the things i have read so far havent worked,wondered if there is something i have missed or something that im not thinking of.oh by the way its not showing and fault codes when scanned either.
