VX Stereo
Pookie
Commodore
Going to take out my old stereo tomorrow just want to know whats the easiest way to get the Stereo out and removing speaking covers in the doors ?
acarmody
Donati..Whoa Green
VX Berlina
Bent coathanger to get the H/U out.
Pookie
Commodore
Ok got the stereo out and sub,amp in but still got things to do and would like some opinions
Stereo bracket how do you mount them looks like no room did get told pop rivet them in but how do you get a drill in to do the holes ?
Where is a good place to mount the amp ?
Some people have said mount the amp on the Sub but others said no as the vibration can damage the amp
What is the easiest way to install speakers eg should i tap into the genuine speaker wiring or run new wiring ?
Any advice would be good
holdenboy
Custom Car Stereo Systems
Nelson Bay NSW
VR Wagon
OK
1. You mount the cradle for the head-unit in the upper half of the cavity, most people are content with just jamming it in there (it a very tight fit at the best of times) and then using a snap in pocket for underneath. But to do it properly yes you should pop rivet the cradle in on each side, just use a cordless drill with the correct size bit and drill as close to a right angle as possible, a small angle wont affect anything.
2. Good place if it'll fit is on the back of the rear seat, if not then the next easiest place is on the underside of the parcel shelf. Mounting it on the sub box is fine, providing the amp is decent quality. Big downside to this is if you want to take the box out to make room in the boot, its not just a simple two wire disconnection from the speaker box terminal and then taping them up etc. You will need to disconnect the power / remote / earth wires along with the RCAs.
3. If you are just replacing the standard speakers with something like 2 or 3 ways then the stock speaker wiring will be OK, just use some spade terminals and speaker wire to adapt the plugs to the new speakers.
