BigGez
- Apr 25, 2023
- 5
- 1
- 1
- Age
- 29
- Location
- Cairns, Queensland.
- VY 3.8L Ecotec
Hey there, I've been trying to find information on this but to no avail. I have a strange coolant leak coming from what looks like an empty socket/hole for something (I will attach photos) it's directly underneath the pressure cap and it seems to be letting air into the system which will then cause a cup or two of coolant to spew onto the ground after driving (out of the overflow reservoir I assume) I have replaced the inlet manifold gasket a few months back as I'm aware that they go often, I also got a new thermostat and tridon pressure cap so i'm fairly sure they aren't the culprits. The place it is leaking is where I've put red RTV silicone, I thought it was seeping through the edges but i think it's coming out from inside the hole, it looks clean in the photo because its been washed, I want to know if I can completely plug up this hole with silicone to stop it leaking out of there, or is that a bad idea? Thank you everyone.
<a href="https://freeimage.host/i/H87Mmsp"><img src="https://iili.io/H87Mmsp.th.jpg" alt="H87Mmsp.th.jpg" border="0"></a> <a href="https://freeimage.host/i/H87VddX"><img src="https://iili.io/H87VddX.th.jpg" alt="H87VddX.th.jpg" border="0"></a> <a href="https://freeimage.host/i/H87VHgt"><img src="https://iili.io/H87VHgt.th.jpg" alt="H87VHgt.th.jpg" border="0"></a>
