stick a vz ss front on it, 1000 bucks is an unreal price, engine/trans/diff is worth 2k in itself,
buy it if its too hard to fix wreck in, id imagine you would make at least 3 to 5000 off it in parts,
the radiator support is a bolt on part, the only thing that would concern me is that you maybe need to see a panel beater to fix up the unboltable bit around the battery, fuse box area,
best bet is to strip it from from doors forward anything that dosnt bolt up get it straightened by a panel shop,
oh and does all the doors open and shut as it should
