VY V6 not starting
lout
61
Langwarrin Victoria
pull rocker covers and see if valves are moving
Fu Manchu
Get off your phone when you’re driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8, & ya mum.
Yep. There is something off with the timing.
You need someone to get a few sensor inputs hooked up to their Picoscope and start looking at what data is being produced and when in the timing cycle.
malmensa
60
Padbury
VY V6 Wagon
Hey guys, I've read several posts on here and nothing has helped with my problem
Got a vy v6 was doing 100km then suddenly spluttered and then died and hasn't started since (6months) since, it just crank and cranks and tries to start everytime, like the timing is out... it's got spark fuel and air, I've done numerous testing, changed crank sensor, cam sensor, checked fuel pump,filter bypassed hole fuel system, fuel pump in bucket and lines hooked up. borrowed injectors rail and reg still no change, changed plugs leads dfi Coil pack, still no change, coughs and splutters even on stard ya bastard, still hard to stsrt on it. I've checked wirings between the sensors and dfi module, I've added additional earth's, I've had 3 cars jumping it nothing, put bit oil down the cyxlinder to bump compression nothing, tried both the keys for immobiliser nothing, it's honestly just seeming lime the ecu has cacked it, but any other suggestions please, this has got me stumped as a hd fitter, had a lv mechanic mate and he's stumped, no fault codes, no nothing
Kinda obvious, and I am guessing you already did this and forgot to tell us, but have you done a compression check yet?
Henderson576
Bayswater
2001 VX S Pack Commodore 5SPD l36
Havnt had a compression test done, due to the fact of the sudden just stopping and failing to stsrt again, be hard to believe that all 6 cyclinders have suddenly dropped compression
Fu Manchu
Western Australia
You’re not looking for 6 dropped cylinders. You’re looking to confirm engine compression is good. It eliminates a possible cause with factual information.
  • Like
Reactions: Lex
Henderson576
Bayswater
Can almost guarantee compression is down. But shouldn't be that bad to completely prevent startup. Currently in the process of verifying timing. If not I'll just drop another engine in and try that.
