VY Wagon Roof Rails - Removal help
Lovable tomato
Hervey bay
Vy commodore Wagon S2
Hi all!!!
My first post thank you
wanting to know a simple way to remove the black roof mouldings (roof rack) off a VY wagon.
Any help will be appreciated. Thank you
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
They are bolted through the roof, so need to remove hood lining probably and undo the bolts.
If you look on top in the track you will see the flat heads of the bolts.
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
Head lining down the bolts from underside
figjam
Donating Member
Far Kurnell
FJ
Probably full of dirt and rubbish under them ? This is 5 minute job with a Territory, but worth doing if you don't want rust to happen.
