vz alloytec adjuster pulley?
sleek_vp
sleek_vp
brisbane
VS ute
id like to know whick pulley it is?, how do you adjust it to tension the belt? and how do you remove it? cheers for all advice
andyman
The Only 6sp VZ Wagon
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
they have a variable adjustment pulley, so in other wors it has a strong internal spring on the inside of the pulley that tensions the belt,
to remove it, see the pully roughly in the middle and towards the passengers side of the motor, it was a hole where you can place a 3/8 or 1/2 inch bar, insert one the and push in the direction so the belts get slack, then just slip it off,
make sure you draw up a mud map of the belt direction
sleek_vp
sleek_vp
brisbane
VS ute
thanks mate for the info, the first time i atempted it i thought it might be the same setup as the vn-vy v6
