VZ Binnacle Oil Pressure Query
seraphic06
Woodgrain Nut
Adelaide, SA
VZ Berlina Wagon, VS Caprice Series II 5.0
Just a quick query - the genuine VZ binnacle has a volt meter that measures volts (obviously) but what is oil pressure measured in? Is it bar?
07GTS
Australia
VEGTS BUILT BLOWN E85
should be kpa for the oil
Drawnnite
Obviously Unsensible
2000 Vs Ute
id be worried if mine was in kPa.
only goes up to 5!
would assume its Bar
(1 Bar = 100kPa approx.)
07GTS
Australia
yea same thing either 0-500kpa or 0-5bar im just use to reading kpa so if i see a 5 i multiply by 100
Drawnnite
2000 Vs Ute
same same here. working with multiple pressure ranges you get used to converting from one to the other :p
