This will do your head in.
There will also be a inlet air flow adjustment motor at the back of the intake that has no plug as well. (If they used the LY7 intake)
Effectively you can’t get this working properly unless you do a full harness swap, ecm, bcm, pim, key head change from a higher end model (like Calais or SV6) to match the motor.
Effectively it’s like swapping another motor altogether. Like a V8 swap.
The problem you bump into when changing the harness is once you get inside the car to the bcm etc, is the wiring can be different for the dash, climate control, and the gear box was a 5speed on the LY7 motors.
Leave it as it is and it won’t run at all, or very well.
Short answer, remove it. Put an LE0 motor in.
