Bellshazza
HI all.
Just purchased a VZ crewman ute. Fuel Gauge comes from full to empty in about 250km but only takes 30-35 litres to fill to full again ( which is about half a tank).
Calibration or fuel sender issue?
Also Crewman tank is shaped like a saddle bag straddling the tailshaft. There appears to me no hoses low down allowing fuel to balance between the 2 halfs. As the fuel pump/sender is one assembly and sit in one side how does the fuel level balance out between the 2 halfs of the tank either side of the tailshaft ? Is there a hose that may be blocked.
Holden are asking nearly $800 to access and replace sender ( need to drop the tank) so would like to do a bity of investigation first in case simply a calibration issue or a simple blocked transfer hose between 2 tanks.
Thanks in advance for any assistance
Older post but just in case someone else comes across this issue.
Been having fuel issues as well. You don't need take the tray off just slide it back. Although no tray is much easier to work on.
There is a hose that goes over the arch in the tank that comes off the bottom of the fuel pump, inside the small plastic bit on the side of the fuel pump where this hose should be is an O ring, if that is cracked then it stops the fuel been sucked into the pump from the passenger side of the tank. Otherwise the hose could be missing. All the hose in the tank are heat fitted, so if you decide to pull them off you'll need to clamp them when you put them back on otherwise you'll be popping hoses off every other day.
