Vz crewman - what seats will fit
M.morgz
Hervey Bay
Vz crewman
I'm searching for a drivers seat and trim to fit my vz crewman which in my town is proving difficult. Thought it'd help if I knew what other model seats would fit. First to admit I'm pretty clueless when it comes to cars so thought I'd ask here. Cheers
figjam
Donating Member
Far Kurnell
FJ
Don’t know if you mean that the fabric trim, or the foam is stuffed.
I think you will be scratching to find similar trim, but if you can get a good seat foam from a wrecker, (VT > VZ) a motor trimmer should be able to swap the trim and foam onto your base.
diysv6
SEQ
VF S1 SV6 STORM A6: VZ S1 SV6 A5
The foam seat insert in my VZ SV6 cracked along the length of the "bolster".
Bought a new foam seat block for about $120 from Holden. Removed the seat and replaced the foam seat.
Came up really well.
The problem I have is that the fabric covering the seat and rear seat section have become a bit worn. These covers were about $220 or more per piece to restore to original.
Bought some seat covers from an aftermarket supplier - about $70-$80 for both front seats.
They look OK and do the job for an 11 year old car.
