88GreenVN
Next Exit Left
- Jun 12, 2006
- 6,795
- 136
- 63
- Age
- 60
- Location
- Surprise, Arizona
- Dodge Ram Van 1500 5.2 V8
So tell me. Level 3 dash. the loom with forth plug. Put into a exec. What do you get? a Dash with no dash lights, the L/100km read out and no rear demister. Why? Because the the level 3 dash requires another light switch. To control the brightness of the dash you ewither hold it up or down. To do that it sends signals to the BCM. The single wire for the L/100km is acutlly ran through the body loom. So even then you have to cut in your own wire from the 4th plug to the ECU. Now we get to the demister switch. Its not a simple on off switch like that of a level 2. You push it, it sends a single to the BCM to activate the rear demisters for 15mins, then turns itself off. You can use the demister switch from a level 3 loom on a level 3 as it its a different type of plug too.
The OP said he will "patch" the wires himself.
The easy way to make a patchllom..... cut the L3 loom to bits and toss in the bin, solder needed plugs into exec loom as said above. Job done and next to no cost.
No BCM change needed, no head light issues, no A/C - climate issues, no BCM issues.
Next time please dont be rude on here - it is not a good look and with about 700 posts you should know better.
