My dad said the "checkpower-train" warning light is coming on during long trips, could anyone suggest what could be causing this? It's from an automatic VT V6 97 model.
Sorry to triple post but i think i found out what a few of the codes are...
I think the 19 may be a throtle position sensor stuck
48 is a cam or a crank angle sensor
85 Transmission slipping difference between engine rpm and transmission output rpm
29 is a Exhaust Gass Recirculation sensor
Any information on these would be greatly appreciated... I cannot believe that there is so much wrong with the car, is there a way for reseting the error codes to check if they come back?
error code 85
You can clear the codes by disconnecting the battery for about a minute.
Then take your car for a drive and check the codes again, they may not reappear indicating an intermitent fault.
There's no errors now after i went for a quick drive by the car feels really ****ed, it's lacking in power and sometimes it changes gears poorly, when i first turned it on i had to wait a while cause every time i went to put my foot on the gas the car acted like it was about to stall, after that it worked but with limited power.
Should i just take it straight to a mechanic or should i take it for a longer drive and see what hapens?
