blueholden
- Jan 11, 2006
- 63
- 0
- 0
- VN
k then dude must be your head gasket dont cheak anything else
Pretender said:Head gaskets blow in all sorts of places so water in the oil is not always present, and in most cases the car will still run fine, just getting hot through losing coolant. If it blows into the water jacket it can then blow through to the oil which results in the milky mixture.
2Fast2FuriousDude said:Umm it is possible to have water going to into your cylinders. I have seen myself personally where you check the dipstick and the oil is white mulch where the water has tried mixing with the oil. Also when the car is running, runs like ****, there is absolute amount of steam coming out of the exhaust.
you did read everyones opinions didn't you??blueholden said:k then dude must be your head gasket dont cheak anything else
ones just as quick as the other ....pressure test or compression test.theoretically pressure test will indicate water loss,but not always in practise,unless i mis read the post,there was no mention of water in pots.now as a general thumb of rule,i think 2fast2furious mentioned this,or maybe even you did,the oil would be turning white to creamy colored if water was entering via bore,(not always though)but it also can enter via inlet manifold,thru the valley.also stated head gaskets can blow any where,and does not necassary mean that the motor will run like a dog.now the problem that was described was bubbles in tank when idling and when hot and even with revs and coolant loss,now they didn't say there was any visible signs of external leak.this bubbling in tank /radiator is consistant with a blown head gasket.now taking steps into rectifying this problem is elimination.OK we agree pressure test is a good starting point,but theres no evidence of external or internal leaks.now from memory they didn't say how their motor was acting...missing ,etc,but a compression test can also come back negative too,it depends on where the gasket is blown.if the water pump was shot,the seal would be leaking and allowing coolant loss to be evident by it dripping from bottom hole,also if water pump bearing was shot you would hear it,so that eliminates the water pump.as for rot in the cooling system there shouldn't be any if coolant has been used in the entire service life of the motor.other things to check is welsh plugs on the V's and check to see if any water is coming from back of motor down thru where the gearbox butts up to motor,indicating welsh plug leakage behind motor.steel plugs and certain brass plugs ARE prone to rot,why just them i don't know,the ethylene glycol maybe reacts more to these ..who knows.mouce said:I'm going to stay out of the bitch fight starting here but I will say that if there is water getting into the cylinders then getting it fixed sooner rather than later would be good. Getting rust on your piston faces isn't fun or cheap. A friend with a little Daewoo did a head gasket and didn't notice until the car died. Three of the four pistons had to be replaced, so they just ended up doing a full rebuild.
Doesn't matter what engine you've got, that ain't cheap.
Go the pressure test first, and work your way though it from there.
samuels said:now the problem that was described was bubbles in tank when idling and when hot and even with revs and coolant loss,now they didn't say there was any visible signs of external leak
mattis96 said:guys thanks for all the advice and i've got around to doing a few things, um i checked the spark plugs and they were only all replaced about a month ago to, but the drivers side ones all looked fine, like they still had that silver look on them, the other side looked dirtier. im not sure what that means.
When i was talking to the guy that usually fixes my car (plus he has been working with cars for like 17 years and owns a radiator shop to) he reckons that i might have just gotten dirty fuel making it blow that funny colour smoke out the exhaust ant the water to and that its probably running to rich to, as i only noticed the problem when i filled it up anyway. even though it was bp ultimate he still thinks it was that.
And as for the bubbles in the radiator he reckons it was just boiling as the fan hadnt turned on yet so thats why it was bubbling, so i'll believe him.
but im still going to get it checked with the pressure test thing to as i dont really wanna take any chances.
someone also said about how the car was running, it is still running fine like it use to, not rough or anything but i have been taking it easier now anyway just in case
