water for battery
baza
71
central coast, nsw
vy ss 2003 auto sedan
dunno if this is the right section , but can anyone tell me if its ok or not to use filtered tap or town water to top up our car batteries. yes, i know i`m a cheapskate but if it saves buying distilled water , why not. thanks if you can help.
ephect
Donating Member
VS Acclaim V6
its best to use distilled, but if none is available, then filtered tap water is fine.
vpcommo
vr berlina
yeah filtered is alright, some mechanics will use pura tap to fill up batteries, but best always if u can to use distilled
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Distilled water is cheaper then a new battery, or doing damage to your car.
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Filtered water does not have the impurities that damage the battery cells removed....you need either distilled or de-ionised water. You can gather rain water or boil the kettle and condense the steam. Bore water is worst of all for batteries and lots of places now have bore water mixed with dam water like Toowoomba.
the collector
the collector
adelaide
rodeo dual cab
bty
distilled water isnt expensive
calling your mate for a jumpstart at 2am will cost you at least a carton,and a tow truck even more.
batteries are only reliable for a couple of years anyway imo
cheers
baza
71
central coast, nsw
well i think it will be safer if i keep useing distilled water . i just wanted to know if filtered water would remove the harmful minerals. but after reading your replies i wont use filtered water. cheers 2 you all.
WhiteOx
96 VS II Acclaim
Just use tap water, I've used tap water for many,many years without any problems whatsoever.
VT-565
QLD
VT
Demineralised water is the go.
If you're gonna pour filtered tap water in there, you might as well just top it up with the garden hose.
OzJD
Bankstown, NSW
jeltel.com.au
2010 Holden Caprice V II (V8)
Yeh I know people who've used normal tap water (from Warragamba damn) and had no issues in years (I have more issues than they do :()
