yezzzah
- May 22, 2023
- 1
- 0
- 1
- Age
- 21
- Location
- nz
- vy executive s2
Howdy legends
I haven't had my VY V6 long but have run into an issue with it overheating. Twice. I have since flushed both the engine and radiator of old coolant using water and it has been filled up with new coolant and bled of air.
Even though I'm sure the air has been purged from the system, I am still hearing a lot of sloshing in/around the engine bay/ dash, please note that the heater and aircon in this car have never worked properly while I've had it (seems to only blow ambient air and makes a lot of noise but not a lot of air gets pushed around) and no I have not flushed the heater core as I'm not quite sure how. Has anyone else had this problem? I've read about there being water in people's door sills but I'm quite sure this is not the case. The only other symptom I have read about so far is a leaking heater core, in which case I am not having the common symptom of a wet passenger-side floor.
Hoping somebody has been in this situation and could possibly shed some light, cheers
-Update,
Thanks so much for your replies, I've found them all useful and appreciate you guys for sharing your knowledge.
I've been super slack at getting this sorted but am going to start off by getting a new radiator cap because as I forgot to mention -My coolant overflow is currently always full so I think there may be a problem with one of the valves in it not creating a vacuum to suck the coolant back into the system.
Will do another update as this progresses or the problem is resolved.
Thanks again, Wizards!
-Update,
