What does tube on air intake tube do
Jatzcracker69
21
Far North QLD
Holden commodore sv6 ute
Can someone explain what the tube that connects to the air intake tube after the maf sensor does, I always thought that this let fresh air into the crank case on the passenger side, and then the driver side had the pcv valve that allowed the positive pressure to be vented along with dirty air back into the engine to be reburnt, but Ive noticed I’ve been getting oil in the passenger side tube, and also a bit of oil in the vaccum tubes. Can someone explain how all the vacuum, pcv system, and passenger side tube systems all work? 08 ly7
Fu Manchu
Get Off Your Phone When You’re Driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8 (VE Calais)
Improves throttle response.
m_r231125
21
Maryborough australia
Holden calais 2006 ve
I lost the attachment that goes into the back of the engine on the passanger side so i currently have no hose on it at all cars currently throwing low injector voltage codes could this be why? The car also has basically no throttle response to
Fu Manchu
Western Australia
Wait? Which tube are we taking about? The intake pipe has a dead end tube on it (on some models) before the throttle body. That’s what I thought we are talking about.
Fu Manchu
Western Australia
I lost the attachment that goes into the back of the engine on the passenger side so i currently have no hose on it at all cars currently throwing low injector voltage codes could this be why? The car also has basically no throttle response to
I’m going to need a bit more info there.
If you have any part past the MAF sensor (behind the air filter) exposed to drawing in air, you’re going to have a bad time.
m_r231125
21
m_r231125
21
That pipe I currently don’t have in, the only codes I have tho are low injector voltages to cyl 1,3,5
Fu Manchu
Western Australia
That is very important. Get one.
Fu Manchu
Western Australia
It’s part of the PCV system. You currently will have issues with crankcase ventilation and you also have a massive unmetered air leak. The ECM will be working hard to compensate for it. The Mass Air Flow sensor (MAF) is behind the air box. It measure the volume of air going in. Aside of a few other sensors between, the O2 sensors at the back are measuring oxygen and all work together to manage injector fuelling.
I would also suggest going to our how to section. Look for Alloytec PCV mod thread. Get that done as well.
I’d suggest replacing the other PCV pipe that connects to the intake plenum and right hand valve cover as well.
