What is this?? looking for temp sensor
Snotty
37
the shire!
VR Berlina auto s2
G'day,
grabed myself a temp gauge and im having trouble finding the sensor. Im looking underneath the aultinator and im a bit confused.
I attempted to take a photo, but its really bad.
Am i looking in the wrong spot>
any help would be GREAT!
thanks
Harvs82
41
Glen Waverley VIC
MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
The thing with the green wire is the temperature guage sender, which obviously sends the signal to your temp gauge in the dash. The thing with the blue plug is the Coolant Temp Sensor, which relays info to the ECU, for controlling the cooling fans amongst other things.
Snotty
37
the shire!
VR Berlina auto s2
excellent, thats wat i was thinking
thank you so much!!!!
Harvs82
41
Glen Waverley VIC
No worries mate, I've just been having problems with the temp guage sender in the parents VS... so I knew exactly what you were looking at.
Snotty
37
the shire!
VR Berlina auto s2
cool, maybe you can help me.
My mate gave me a water temp gauge, cause his brother crashed his car and doenst want it.
And i know NOTHING about them.
I dont know how to wire it up, there are 2 wires for the backlight, and one thick black wire, about 20 Cm long, assuming its been cut.
What more do i need to install it?
thanks
Snotty
37
the shire!
VR Berlina auto s2
anyone?
is there a way to test the guage to make sure it is still working?
vt1538
455rwhp LS3
55
The Dead Centre
VY SS S2 11.284@125mph
That thick black wire sounds like the capillary for a mechanical temp guage. If it is the guage is useless.
V
vrd00m
Guest
does the black wire have coppr or metal inside it? or is it hollow like a tube?
if it's hollow it's mechanical, harder to install and prolly not worth it
if it's got wire in it, hook that up tot he wire form the sensor in your pic.
tally ho :p
vt1538
455rwhp LS3
55
The Dead Centre
A mechanical guage if it has been cut can not be used as the fluid in the capillary tube is gone. If the black wire is @ 6mm thick then it is mechanical. An electric guage will only need 2mm wire.
frednurke
78
2009 VE Sportwagon
VS Temperature problems
I solved the overheating problem in my VS wagon by adding another themistor in parallel with the existing one in the fan sensor. This is relatively easy to get apart. This gives a lower temperature operate point for the fan and hence the motor does not get as hot.
The standaard GMH fix is to replace the gauge sensor to make it look like it's running cooler.
Thanks for the post re a key fix. Has saved $$$$.
