ari666
250,000 hits
- Mar 10, 2009
- 11,835
- 128
- 63
- Location
- melbourne
- 1966 impala, R32 GTR
so i have had an ongoing erratic vacuum issue on my latest build, manifold vac has been bounching rapidly over about 6 inchesHG. i redid my inlet manifold 3 times, tried three different carbys, checked rechecked and re-recheck all hoses ports etc etc etc.
a little history; one fine day about 3 months ago a valve spring snapped on me while i was sitting quietly in traffic. wasnt revving, just idling and the vac starts going mental bouncing from 0-15INHG. so fixed that. and vac just goes back to being erratic.
now, two days ago i re adjusted my roller rockers, but this time, rather than the "find zero lash the tighten 1/2 a turn" that crane recomended i just did zero lash and about 1/100th of a turn. start the car, vroom, erratic idle still *sigh* no worries, i need to look elsewhere. anyway as i drive the vac gets more and more stable. to the point where this morning it was rock solid on 9 inches...
would over tight rockers snap a spring?
would they burn out valves?
would it burn valves, but then clean the burn off once they start seating properley?
would it cause pinging?
crack the head?
or anything else horrible you can think of. it has crane anti-pump lifters if that makes a difference. and it is rather fast too it still got its 147.5 with erratic vacuum and tight rollers. the dyno guy didnt mention it.
thanks fellas
crack the head?
thanks fellas
