Where is the bleed valve located
sazzizle
VT Commodore 1998 V6
Does anyone have a picture or diagram of where the bleed valve is located for a VT 1998. I am having problems with my car it seems to be overheating and then returning to a normal driving temperature soon after.
Wombles
Cars cost too much.
Right on top of the thermostat housing.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
It's on top of the thermostat housing where the top radiator hose connects.
It's just a small grub screw with a slot for a flat baded screw driver.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
The top radiator hose is connected to the thermostat housing, you will find the bleeding screw there.
Edit: A bit late.
sazzizle
I flushed the car and ran the car until it reached normal operating temperature, however the fan had not come on. I noticed the radiator hose started leaking and steam started coming out of the radiator and the hose was too hot to touch. What could cause the car to overheat like this so quickly?
wortus
Overheating should not cause steam to come out of the radiator hose, sounds like the hose is not tight enough or needs replacing? The radiator cap should just open and you may see a bit of steam come out of there? Sounds more like you have a leak, Hose will be pretty hot either way.
sazzizle
Yeah after I saw the steam come out of the radiator, I turned the car off and thats when I saw the hose leaking...it was not leaking before I turned the car off. Is the leak in the hose the only thing that may be causing it to overheat this quickly, or could it be the water pump?
sazzizle
water tap.jpgAlso the water tap seems to have what looks like corrosion around it. It has a white/pinky substance all over it. Does this need to be replaced?
