White smoke...
yZoH
//There Ain't No Rest For The Wicked...
S/E Subs, Melb
www.lolwut.com
(0.o')
Hey guys today i noticed my car sucked a bit of oil an it's blowing white smoke quite bad... Any idea how I can fix her.... Gaskets or what?????
MaT
P.S- Just come to the conclusion might be piston rings, I'm scared like a mofo right now...
azkwazere
Ahhh Yes, Ahhh Yes....
33
.....SE Burbs
VP 5-SPD / 24-SPD Racer Hybrid
ohhh shittttt...........
Thats not a gasket..... :(
Ummmm..... hmmmm..... rebuild???
I donno, could be rings, sounds like your rings, would explain smoke anyway, how good are you at ripping apart your block?
aZk.
sircruisealotVS
South Brisbane
VZ LS1 Calais
is this smoke completely white?...as in no tinge of blue or anything, just white.
because pure white smoke is usually water/coolant being burnt in the exhaust....hold a white cloth over the exhaust tip for a minute and see if it becomes oily or just a bit damp.
it could be a bunch of things at this point (valve seals, valve guides, piston rings,etc.) narrowing it down by finding out for sure whether its oil or not will help.
Shortstuff
Random
2016 Golf GTI PP
Try coasting down a hill without applying throttle, but making sure the revs are at about 3000rpm. When you get to the bottom and accelerate away, if it smokes then, it's probably the valve stem seals. This is easier in a manual,but still possible in an auto if you stick it in 2nd gear I think.
If it just smokes on acceleration (without idling first) then it indicates rings.
I had an old Vauxhall Nova that used to make everything behind it disappear each time I got to the bottom of a hill because the valve stem seals were shot. It ran for ages like that though!
matt8
could be tyre smoke by the look of your little pic?
yZoH
S/E Subs, Melb
www.lolwut.com
(0.o')
Ok well...
1- Held rag over exhaust tip, Water not oil..
2- Can't do compression test, our tester wont fit "have to get another one"
3- Already put metho in fuel so not water in fuel
4- No oil in radiator coolant
5- Car's been idling passed 15mins an waters justpissing out exhaust.... Radiators not losing water....
6- Head gasket is my last resort........................ Goin to open radiator cap with rag an see if she's bubbling.
MaT
yZoH
S/E Subs, Melb
www.lolwut.com
(0.o')
Ok..... Error 13.... Oxy sensor, are series 1 & series 2 oxy sensor's the same?????
Also would 13 make my car puff white smoke like puffing billy...
MaT
yZoH
S/E Subs, Melb
www.lolwut.com
(0.o')
Poured 1ltr of metho in fuel tank, Fuel system cleaner, Stop leak in the engine oil,
!!NEW VT V6 INJECTORS!!
HOLY ****!!!!!!
The new injectors have made it purrr or should i say rumble it is awesome! So much more power, pod whistles twice as loud.....
MaT
burnz
dah dut dut da dah
springfield
VFII SS ute M6
i was going to ask if you have a pod.
is it possable you over oiled it?
nathans1987
33
W.A. Perth
4316.awardspace.com
VX SS 5.7L M6
white smoke means burning oil through the rings ie a worn about to die motor most likley.
