If they are anything like the 3.6 litre i wouldn't be putting extractors on. It will change your air flow past the sensors and all day you will have a check engine light. I've seen it happen to many times to our customers. Every single person I know that has fitted extractors have had a check engine light pop up.
I was planning on a big spend soon, so I was thinking to just put everything on at once and get a tune, id want everything there when I get the tune so there isn't any check engine light later on If I get these after, I'm planning on, mace manifold spacers, 20-25% race underdrive pully kit, don't no what one, otr cai (orrsum) I have a redbaCk catback exhaust so il put extractors on it as well, and then a dyno tune, it's the only things I can think of that thy can do to a my sidi 3.6l engine. And I'm getting a hi proformance steering pump today because I blew up the stock one from doing doughnuts haha
Ok I'm. Bit ####en confused now, I have a sidi engine LLT I was looking at the extractors it's not 1 output like people have said, it's got 3 on each side wtf does that mean I can use normal extractors? Wtf
The newer of the Series2 VE's (built in 2012) have a different configuration V6 3.0 and 3.6ltr SIDI engine. These are identified as LFX. Basically the engines exhaust manifold is intergrated into the design of the engine head resulting in just a single engine pipe being bolted to the head going to the CAT.
