Stewart1000
work done by ME
- Sep 4, 2005
- 797
- 9
- 0
- Age
- 34
- Location
- vic
- Website
- www.justcommodores.com.au
- VL twin turbo. VN5L. old jeep, **** mondeo.
why dont you hear of many people making up a turbo kit from parts found on ebay?
here are soem things i found:
NEW FMIC 450x300x76 Intercooler Turbo Exhaust Apexi HKS
AU $179.00
**RRP = 539 +
** Up to 550 HP
** Good for Factory turbo or update TURBO !!!
** Life Time Warranty !! ( by Automotorsports - IMPORTER
NAME: Universal Polished Bar & Plate Intercooler
MODEL: 450x300x76 -mm
SPECIFICATIONS: Core size: 450x300x76
Overall Size: 600x300x76mm
HP Rating: 480-600 + hp
Flow Test: 381.3cfu
Fully Polished
3" inlet and outlet
Comes with end tanks, fully welded.
Low Cost, High Efficiency
Fit most cars
TURBO BOV :: BLOW OFF VALVE ::
AU $49.00
Turbo XS Style BOV
Atmosphere Vent Model
B/N RB20/25DET MANIFOLD..T70 TURBO AND 35MM WASTEGATE!!
AU $511.75
HUGE POWER GAINS!!!
RB20 RB25DET ENGINES!!!!
YOU GET:
1) HUGE T70 TURBO
WET FLOATING BALL BEARINGS
SHAFT & WHEEL TRIM 64.5mm
COMPRESSOR WHEEL SUPER 70 60.5mm
( similar to Garrett T61 for comparison purposes )
TURBINE HOUSING A/R .84
COMPRESSOR HOUSING A/R RATIO .70
T3 Flange
2) RB20/RB25DET CHROME MANIFOLD
321 STAINLESS
TOP MOUNT
(2) BOLT 35 MM WASTEGATE FLANGE
42MM PIPE DIAMETER!
2.6MM THICK - WILL NEVER CRACK!
T3 Flange
3) 35MM WASTEGATE
INCLUDES ALL GASKETS
COMPLETE BOLT KIT
Accurate boost control and high quality appearance.
The spring rate is Adjustable.
that all adds up to $739.75 and you still need to spend a bit more on the setup but im sure it would add up to much less than a new turbo kit.
What do you guys think?
AU $179.00
**RRP = 539 +
** Up to 550 HP
Flow Test: 381.3cfu
Fully Polished
3" inlet and outlet
Fit most cars
AU $49.00
Turbo XS Style BOV
AU $511.75
HUGE POWER GAINS!!!
YOU GET:
1) HUGE T70 TURBO
T3 Flange
321 STAINLESS
TOP MOUNT
42MM PIPE DIAMETER!
T3 Flange
3) 35MM WASTEGATE
COMPLETE BOLT KIT
