will a holden 5 litre take 11 PSI boost at 10:1 compression ?
huntsman482
VN Calais, WH Statesman V8
Can someone please tell me if a holden 5 litre 304 out of a VS take 11 PSI boost at 10:1 compression or will the supercharger do damage , or get damaged , thanx in advance
AirStrike
91' VN SS
It's really not that simple to say yes or no, too many variables. Sit down and discus it with your tuner.
huntsman482
i was inquiring about this for my son actually as he is a diesel mechanic by trade & his head is telling him it will do damage if he runs 10:1 compression ratio , as the standard ration is normally 8:1 ratio , but he was wondering if someone has already tried this with success , or if it resulted in failure ,, , but thanks for the response though :)
huntsman482
the blower that is on the vehicle is a centrifugal
AirStrike
91' VN SS
Depends on the fuel used, cam specs, head setup, etc, etc, etc.
Speak to the tuner.
mr j-man
GC
VH SL/E 355
you can run a cometic head gasket just to get it lower if the 10:1 is borderline...running the cometic should take it to 9.8:1
