Will these spline wheel nuts be a safe replacement for oem wheel nuts?
jeffmills69
2011 VE Wagon
There isn't as much flare as oem but they still have enough to hold the wheels in place, just figured I'd double check and see if anyone else has used em?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Are they 14mm, will they screw on a VE wheel stud?
shane_3800
35
places
vr commo
They aren't ideal. Aftermarket wheels will have more meat behind the taper.
shane_3800
35
places
vr commo
jeffmills69
2011 VE Wagon
yeah they screw on and don't fit through the stud hole in the wheel at all
Fair enough, what sort of dangers are possible? Is it possible for the nuts to sorta pull through the taper in the stud hole?
Took pictures of em on the wheels, definitely not as much contact as OEM but they do hold the wheels on centered to the studs.. also had to give em more of a turn with the breaker bar when tightening
shane_3800
35
places
vr commo
If you hit a pothole hard enough it may be possible to crack the wheel.
Fu Manchu
WA.
I just bought a set of locknuts the same. Came with wheel nuts too. Still a good price. The VZ nut has far more surface area contacting the wheel. I figure might be fine for the lock nuts to be a bit of a smaller surface area.
lmoengnr
Donating Member
Sunbury Vic.
They look better suited to a 12mm stud.
Skylarking
123
Downunder
Commodore Motorsport Edition
