window rattle when volume turned up?
djeyecon
black is back.
Narellan, NSW
VU Ute 3.8 S V6
is it my runners? can i get some dynamat to prevent this or is it because my window isn't secured properly? if i roll up my window a couple of inches the rattle goes away.
any suggestions?
HamaTime™
VIP Member
C Class AMG
any suggestions?
It's normal, just happens with cars that have been around for a while...if you want to fix it properly then its a massive job taking the door and windows apart to fully adjust and reseal everything...just wear and tear of the car mate...all about friction and rubbing points
djeyecon
black is back.
Narellan, NSW
VU Ute 3.8 S V6
fair enough. i'll deal with it for now
cewing
Castle Hill
VE SSV SWAGON
I have the same. if i put my window down a smidgant, it instantly goes away. bf if i know why though.
VY.abercrombie
NSW
VY S soon to be SS
my cars the same. put ur window down or up a few mm and should be fine.
djeyecon
black is back.
Narellan, NSW
VU Ute 3.8 S V6
lol yeah clearly.. the whole point is to find a solution other than putting my window up abit...
jafo
lurker since 2003
adelaide
1999 wh statesman
turn the volume down till i stops:rofl:
Denno
35
South Adelaide
VX Commodore Lumina
My window used to rattle when I had it down, all the way down or a little bit. I have since had to get a new power window regulator, as the old one fell apart, and the problem is now gone. So I guess my problem was the regulator, dunno if you can check that too easy..
gdunkley84
I Have a Dent.
Orelia, WA, 6167
2009 VE SSV Sportswagon
The product you want is called bailey channel and it goes in the channels on each side of the window where they run up and down. In older cars this starts to harden up and create rattles.
It can be a prick of a job though. Probably require taking window out sometimes.
