window winder
Aidan
can anyone tell me how to put u ring and window winder back onto door
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Just put the ring back on the handle and then push the handle back onto the shaft, maybe give it a sharp tap with the palm of your hand.
Aidan
thanks accentstencil do i put it though the winder hole bit or just sit it there
accentstencil
71
Push the clip into the two slots on the winder and then push the winder onto the shaft that you took it off from. The shaft has a slight taper and that will allow the clip to spread a bit and then it will click into the groove on the shaft when you push it on.
