windsheild vent stuck open
Shenic
Gold Coast
VZ
Hi
has any had a problem with the direction flow switch on VZ it contiually blows on the wind screen even when I turn the knob to other positions.
bcw61
Northern suburbs of Adelaide
VZ 2005 Executive Wagon
Sounds like a classic case of no/low vacuum to the HVAC actuators. Check the vacuum system for leaks - simple checks include the security of the vacuum connections to the engine manifold vacuum take off point, one way valve, the vacuum reservoir or the vacuum solenoid pack (climate control HVAC only).
If no fault found, then one or more of the vacuum actuators could be leaking, or the selector valve may be leaking (manual HVAC only).
Hope this helps.
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Drivers side rear of the manifold. Take the engine cover off. There is a small vac hose that usually comes off.
