remorseful1
- May 20, 2023
- 1
- 0
- 1
- Age
- 37
- Location
- WA
- WL Statesman 3.6l
Hi all. New to the forum but been reading it for years and can't find what I need.
So my wonderful Statesman decided that it didn't want to start with the tell tale ping of the solenoid. I took out the starter and rebuilt it with a newer solenoid which worked fine.
Car started after that, and was ok to drive. First placed I pulled up, I stopped the car and when I came back to it, it wouldn't start but was trying to crank really fast.
Tried starting it a few times but it wouldn't turn over. I came back to the car a few hours later and it started first try.
Same situation kept occuring so I started checking things like the battery and alternator. Battery was fucked but the alternator is good as gold output wise ( 13.6 volts ).
After all that it still isn't starting and I am at my wit's end with this car. All the coil packs are new ( 3 months ago replaced them) and so are the spark plugs. All my relays are good and functioning properly.
Fuel pump is working properly but could be a little blocked. When the car is running it runs pretty smooth and doesn't struggle for power or anything.
I'm about to start testing where the relays slot in and then test the coils. Is there anything else I could be missing?
I was supposed to start a new job on Monday so I am a little limited on funds to throw at it.
