Wn to vf front end
Mangcaprice
Australia
Wn caprice v
Hey I’m just wondering if anyone might know. Will the vf front end (guards bonnet bumper and lights) fit onto a 2014 wn caprice. Is the body shape different are the mounting hole’s different is the bonnet latch different
Fu Manchu
WA.
It’s all the same in that part of the car.
Fu Manchu
WA.
Fu Manchu
WA.
Actually come to think of it, the bonnet hinges will be the expensive bit. The WN uses a VE hinge. There are some really iffy ways the VF hinge can be attached and none of them should be even attempted or done.
The hinge needs to be removed. It’s spot welded to the body. The VF hinge needs to be spot welded in place by a panel beater. Don’t do this yourself unless you are a competent and experienced welder.
